1/48 Tamiya P-51D Frenesi
 Список форумов Форум моделистов на ScaleModels.ru -> Самолеты до 1950 - США -> Самолеты США до 1950 - North American
Сожгу мосты, чтобы назад пути не было )
Добрый человек в лице Алексея ReservourDog пообещал мне деку на Френези, так что придется купить к ней кит, смолу и все, что полагается.
Кстати, деку на Р-40 мне тоже подарили, и модель долетела до финиша. Проверим тренд... Wink
Удачи.
Главное, форкиль срезать и перепилить переход в киль правильно. Там расшивка изменится.
AC
А, то есть без камасутры все-таки не обойдется... жаль (
Добавлено спустя 3 минуты 3 секунды:
Modeler Tips:
Side View Notes:
A.
Rear red band on propeller boss extends onto spinner to leading edge of blades when in neutral pitch. Determine width of yellow band by dividing remainder of spinner evenly.
B. 85 bomb-style mission marks in eight blocks of ten and one block of five. Note spacing between the blocks, six along upper cowl seam with two and a half above. Space between first block and checkers equal to spacing between each block of marks.
C. "Frenesi" in USAAF yellow splashed across both strip panels beneath exhaust on port side, serifs on the letter "F" overlap rear row of checkers slightly- ends of the word overlap panel seams and extend down to lower portion of nose.
D. USAAC Project Number in black over natural metal.
E. Plate for Pilot and crew names descend from left in yellow over black.
F. 11 kills, single column of two Japanese battle flags followed by nine Reich Flags in four columns of two plus a single one above opening for signal pistol tube. Tommy Hayes was a member of a very small fraternity of pilots who cut their combat teeth in the Pacific Theater flying P-40's- and he brought two confirmed victories over Japanese aircraft with him to Leiston.
G. Canopy framing above sills left natural aluminum.
H. Antenna post had bottom 8" painted dark olive green, remainder natural metal. There were no antenna wires installed on this aircraft.
I. Tail Number- "413" on fin, "318" on rudder in yellow.
I. Sides of radiator ventilation flap were natural metal.
J. Reduced invasion stripes come up to within a couple inches of uppermost panel seam. Note that the black fuselage code letters overlap the camouflage.
Upper & Lower View Notes:
J. White recognition stripes, both upper and lower, were of standard widths on wings & stabilizers for mid-1944 ETO Mustangs.
K: Width of checker reduced on underside in order to fit evenly on the narrow surfaces of the chin scoop area.
L, M, N. Red, Green, Yellow navigation lights- circular and flush with wing panel.
O. Formation Lights- Red (Port) and Green (Starboard)
Overall Modeling Tips:
*This aircraft wore Dark Olive Green camouflage over USAAC Medium Gray. Note area of natural metal reserved for project number. Paint on the flat colors first (recognition stripes, camouflage areas) then mask off and paint a rectangle color for the project number, and the canopy framing indicated, in a natural aluminum color. Most metal colors will be marred or removed by masking materials so it's often better to leave them for last.
*After building several 357th A/C over the past 30 years, I recommend painting the nose area forward of the exhaust cutout yellow when the flat features are painted. Carefully cut away the yellow squares from the checkerboard decal and apply the remaining strip of red checkers to the nose. This method significantly reduces the potential for bubbles and wrinkles, plus it makes exact alignment of the decal easier.
*Prior to assembly, wash clear plastic parts with a mild glass cleaner and gently wipe dry. Then use a Q-Tip to evenly spread clear liquid floor wax (Future Brand seems to get the best results) on both inside & outside. Protect from dust and let dry for at least 2 hours. The wax fills in microscopic flaws and creates an even gloss that is clearer & shines brighter than the original plastic underneath.
Ну есть вариант проще - купить B-шку, отпилить хвост по расшивке, и приклеить к D Smile
Нажмите паузу.
Сегодня куплю модельку, а там поглядим с кем это будет и в каких позах...
Вариант не проще ибо одно к другому без запила просто так не стыкуется. Стыкуется с большой ступенькой и выводить всю часть до киля таки придется напильником и двухкомпоненткой. Знаем. Примеряли, питая те же надежды.
Лучше было бы Хасегаву взять - там киль полностенный, а у Тамии пустотелый, про Монограм не говорю - не всем охота перешивать модель, хотя есть там и плюсы - на крыле не нужно шпаклевать крой Smile
Офигеть понасоветовали. А просто купить модель и получить наслаждение от сборки никак?
Ну форкиль отрезать еще куда ни шло, но покупать две модели, чтобы геморроиться над одной...
Макс, у меня еще есть "Detroit Miss" с желтым носом, форкиль отрезать вроде не надо Smile
есть еще "Dallass Doll" Тоже ничего отрезать не нужно Smile
Только они серебристые и не известно были ли они во время Нормандии. Полосы есть.
Кстати, а "Красные Хвосты" принимали участие?
Леша, кам даун...
никаких двух моделей не будет.
я сейчас спокойненько поеду в магаз, куплю там тамию с нишами и буду на нее все выходные медитировать...
Tali писал(а):
Леша, кам даун...
Может сделаем проще, ты купишь Тамию, а я тебе отдам все деки на Мустанга? В обмен на Тандера (шутка) Smile Выберешь, что понравится.
ReservoirDog
Ты сейчас не проще, а сложнее делаешь.
Деку я уже выбрал. Как следует из названия темы - на Frenesi.
Осталось купить все остальное.
А на Тандер у тебя бесплатная доставка будет )
Насколько правдиво данное фото? В том плане, что тут есть форкиль.
ну, с другой стороны можно другой прототип выбрать, чтобы не пилить, ибо не хочется, если честно.
модель и ниши уже дома )
Ну так выбери себе Smile
На этой нет частично технички, знаков и варианта с теткой на зеленом фоне.
Ладно, разберемся... Уж что-что, а дека на Мустанг вряд ли будет проблемой.
в игноре у 18 пользователей
"сюрвейвер", это он сейчас Френнеси.
Для превращения тамиевского Мустанга, который по сути является самым поздним вариантом - D-25/30, кроме спиливания форкиля много еще чего надо сделать.
Можно смотреть в соседней ветке http://scalemodels.ru/modules/forum/viewtopic_t_52729_start_0.html. Там с картинками показано.
Также у этой машины руль высоты ранний, с полотняной обшивкой.
prokhor
Наверное, буду еще деки смотреть - запил не входил в мои планы (
Тогда лучше P-51B делать, из Д-шки просто машина нормандийская не получится. Там все ранние машины были, Д-5 в основном, некоторые, правда с форкилями, как E2-S из 361 группы.
