Íàøè ïðîåêòû: 3D ïå÷àòü è óñëóãè : Wiki : Ñóâåíèðû : Walkarounds : ÂÍÈÌÀÍÈÅ: Ñàéò ïîêà ðàáîòàåò â òåñòîâîì ðåæèìå ïîñëå ïåðååçäà! ×òî-òî ìîæåò ðàáîòàòü íå òàê êàê îæèäàåòñÿ, ïðîâåðÿåì...
Âîéòè Ðåãèñòðàöèÿ
Ôîðóì ìîäåëèñòîâ íà ScaleModels.ru
 Íàáëþäàåìûå òåìûÍàáëþäàåìûå òåìû    FAQFAQ   ÏîèñêÏîèñê   ÏîëüçîâàòåëèÏîëüçîâàòåëè   medals.phpÍàãðàäû   ÈçáðàííîåÈçáðàííîå   ÐåãèñòðàöèÿÐåãèñòðàöèÿ
  Íàáëþäàåìûå ôîðóìûÍàáëþäàåìûå ôîðóìû  ÏðîôèëüÏðîôèëü    Âîéòè è ïðîâåðèòü ëè÷íûå ñîîáùåíèÿÂîéòè è ïðîâåðèòü ëè÷íûå ñîîáùåíèÿ   ÂõîäÂõîä
À6Ì2 çåðî 1/48 Òàìèÿ - âîïðîñû.
Íà ñòðàíèöó Ïðåä.  12
 Ñïèñîê ôîðóìîâ Ôîðóì ìîäåëèñòîâ íà ScaleModels.ru -> Ñàìîëåòû äî 1950 - ßïîíèÿ
íîâàÿ òåìà  îòâåòèòü  äëÿ ïå÷àòè Ïðåäûäóùàÿ òåìà Ñëåäóþùàÿ òåìà
Àâòîð
Ñîîáùåíèå
â èãíîðå ó 4 ïîëüçîâàòåëåé
âîò åñòü òàêèå êàðòèíêè ïðîöåññ ñáîðêè òàê ÷òî çà öâåò òî?
Âîò ýòîò öâåò åùå â íèøàõ:
çàêàí÷èâàåò äîêà÷èâàòüñÿ âèäåî ïî ñáîðêå hasegawa a6m3 zero type 22 1.48 äóìàþ òàì ìíîãî ÷åãî ïîõîæåãî è ÷òî òàêæå ïîìîæåò ïðè ñáîðêå. ãîëîâà óæå êðóãîì îò êîëè÷åñòâà èíôîðìàöèè êàê è ÷òî ñäåëàòü....... õî÷åòñÿ êàê âñåãäà âñå è ñðàçó, íî ïîíèìàåòñÿ ÷òî íå ïîëó÷èòñÿ òàê êàê íðàâèòñÿ=)
Õàðóíû÷ ïèñàë(à):
ß òàê äóìàþ, ÷òî ñïîðîì î öâåòå íèø íà ðàííèõ Çåðî Âàì ãîëîâó ëó÷øå íå çàáèâàòü? Very Happy
â èãíîðå ó 3 ïîëüçîâàòåëåé
ó Ãóíçå åñòü öâåò H63 ....ñïåöèàëüíî äëÿ ÿïîíñêîé àâèàöèè.....íàçûâàåòñÿ metallic blue green
êàæåòñÿ ýòî îí íà ôîòîãðàôèÿõ åñëè ÿ íå îøèáàþñü
Èãîðü, ñîãëàøóñü ñ òîáîé, ÷òî ñ Àîòàêå Çåðî ñìîòðèòñÿ ëó÷øå, íî âîò èíôîðìàöèÿ ê ðàçìûøëåíèþ:
Hello Dimmy,
This statement is now known to be incorrect: "All Zeros at PH were Mitsubishi-built. Therefore the wheel wells and inner surfaces of the flaps are dark green translucent aotake color"
The most up-to-date study shows that Mitsubishi painted Zero wheel wells and the inner surfaces of gear doors with the exterior color. Photos of Zero AI-154 that crashed at Fort Kamehameha show the exposed gear well matching the exterior color. Nakajima began production of Zeros in November of 1941. No Nakajima-built Zeros were present at Pearl Harbor. Mitsubishi moved on to produce the A6M3 types 32 and 22 while Nakajima continued to turn out type 21's....
À âîò åùå:
Hello Dimmy,
On Jim Lansdale's new post on the Navy Aircraft Board "Lost Pearl Harbor Aircraft: II the HIRANO Zero" the ninth picture shows the right wing with the leading edge torn away. You can see the black leg of the landing gear and the wheel well color matching the exterior.
The metal paint and the cloth paint have the same value. This means that they look the same in black and white photos. Here is a picture of two artifacts from Pearl Harbor Zeros.
È åùå:
I'm not sure which airframe you are modeling, but, if I may, be careful with your use of Aotake, especially for the wheel wells. Some of the early Zeros had wheel wells (and the insides of their landing gear covers) painted the same color their exteriors.
Isamu
×òî ñêàæåøü? Wink
Êîëëåãà Äèììè! Íå êàæåòñÿ ëè Âàì, ÷òî ïðåäëîæåííûé Âàìè êîëåð ýêñòåðüåðà ýòîé ìàøèíû(íà ñòð.1 ýòîé âåòêè, ãäå Âû(?) åãî íà ðóêå äåðæèòå) ïîäîçðèòåëüíî íàïîìèíàåò ÐËÌ 02? Èëè ýòî öâåòîïåðåäà÷à òàêàÿ? Ó ìåíÿ ëè÷íî ñêëàäûâàåòñÿ îùóùåíèå, ÷òî áàçîâûé öâåò ÷åì-òî ñðîäíè áðèòàíñêîìó çåëåíîâàòîìó "ñêàé". ß íå â ïëàíå êðèòèêè, à ðàçîáðàòüñÿ õî÷ó. ×òî êàñàåòñÿ íèø, òî Âàø èíîñòðàííûé êîëëåãà, íàñêîëüêî ÿ ïîíÿë, ïðåäëàãàåòò îêðàøèâàòü èõ â áàçîâûé öâåò ìàøèíû, òî åñòü ýêñòåðüåðà. ß ïðàâèëüíî ãîâîðþ?  ïîñëåäíåå âðåìÿ ïîøëè çàìîðî÷êè ñ öâåòàìè ðàííèõ "Çåðî", ëåòàâøèõ íà Ïèðë-Õàðáîð. Ñîãëàñíî èíôîðìàöèè ñ íåêòîðûõ ñàéòîâ, îíè ÷óòü ëè íå ñâåòëî-êîðè÷íåâûå áûëè, ÷òî, ÈÌÕÎ, ñîìíèòåëüíî, èáî ìîðå-îêèÿí â ñâîåé ãàììå òàêèõ îòòåíêîâ, êàæåòñÿ, íå èìååò. Êîëëåãà Äèììè, íå ìîãëè áû Âû äàòü ñëîâåñíîå îïèñàíèå ýòîãî öâåòà? Ìåíÿ êàê õóäîæíèêà ýòî áû âïîëíå óñòðîèëî, ïîñêîëüêó ÿ ñ÷èòàþ, ÷òî âàæíû, ïðåæäå âñåãî, íå íîìåðà òîé èëè èíîé êðàñêè, à çðèòåëüíîå âîñïðèÿòèå. Òàê êàêîé æå âñå-òàêè áûë áàçîâûé öâåò? Ñâåòëî ñåðî-çåëåíûé, ÷óòü â êîðè÷íåâèçíó, æåëòèçíó... ÊÀÊÎÉ?
Ñ óâàæåíèåì, Àëåêñàíäð.
Amadis ïèñàë(à):
http://www.j-aircraft.org/smf/index.php?topic=4539.0
Ãëÿíüòå ïî îñòàòêàì ðåàëüíîé ìàøèíû
Amadis ïèñàë(à):
Àëåêñàíäð,
Âû àáñîëþòíî ïðàâû, ñîãëàñíî ïîñëåäíèì "äàííûì íàóêè" ñ÷èòàåòñÿ, ÷òî íèøè ðàííèõ ìàøèí (ò.å. À6Ì2 ïð-âà Ìèòñóáèñè, êîòîðûå ó÷àñòâîâàëè â íàëåòå íà Æåì÷óæíóþ Ãàâàíü) êðàñèëèñü â öâåò íàðóæíèõ ïîâåðõíîñòåé.
Òóò ìû ñ Èãîðåì íå ñîøëèñü âî ìíåíèÿõ, õîòÿ ïðèçíàþñü ÷åñòíî, ÷òî íèøè â Àîòàêå ñìîòðÿòñÿ ãîðàçäî âûèãðûøíåå íèø â Àìå-èðî, è ÿ áû ñàì èìåííî òàê è êðàñèë, åñëè áû íå "íîâûå âåÿíèÿ".
Ïî ïîâîäó öâåòà Ï-Õ Çåðî. Òóò çàìîðî÷êè èäóò äàâíûì-äàâíî, à â ïîñëåäíåå âðåìÿ âûëèëîñü â íàñòîÿùóþ âîéíó ìåæäó äâóìÿ ïðèçíàííûìè çíàòîêàìè ÿïîíñêîé àâèàöèè - Ä.Ëàíñäåéëîì è Ä.Àéêåíîì.
Äîøëî äî òîãî, ÷òî íà ñàéòå Àéêåíà áàíÿò òåõ, êòî ðåãèñòðèðóåòñÿ íà ôîðóìå Ëàíñäåéëà. À âåäü Äæèì - áûâøèé ñòóäåíò Àéêåíà. Ïðåäñòàâëÿåòå, äî ÷åãî äîâåëî ïðîñòîå ðàñõîæäåíèå âî âçãëÿäàõ äàæå íå íà öâåò, à íà ÎÒÒÅÍÎÊ ýòîé êðàñêè?
Âîáùåì, ïîïðîáóþ îïèñàòü Âàì îáùóþ êàðòèíó â äâóõ ñëîâàõ.
Ï-Õ Çåðî ìîãëè áûòü âûêðàøåíû â îäíó èç äâóõ êðàñîê: J3 Hai-Iro èëè I3 Tsuchi-Iro.
Íà ýòîé êàðòèíêå îíè èçîáðàæåíû â íèæíåì ëåâîì è íèæíåì ïðàâîì óãëàõ:
Ñëåâà è ñïðàâà ïðèâåäåíû îáðàçöû êðàñîê ñ îáëîìêîâ Çåðî, ñáèòûõ ïðè íàëåòå.
Ïîñåðåäèíå, ÅÌÍÈÏ, òåîðåòè÷åñêîå îñâåòëåíèå êðàñêè ñ ó÷åòîì ñòàðåíèÿ è âûãîðàíèÿ.
Âåñü ñïîð ñâîäèòñÿ ê òîìó, ÷òî áûëî îñíîâîé: èëè ýòî â ñåðîâàòîì J3 Hai-Iro îò âðåìåíè ïîÿâèëàñü êîðè÷íåâàòîñòü, èëè íàîáîðîò - êîðè÷íåâàòûé I3 Tsuchi-Iro âûöâåë è ïðèîáðåë ëåãêóþ ñåðîâàòîñòü.
Ñóäÿ ïî ýòîé êàðòèíêå, åå àâòîð (êàê è ÿ) ïðèäåðæèâàåòñÿ ìíåíèÿ, ÷òî îñíîâîé âñå æå áûë çåìëÿíèñòûé Tsuchi-Iro.
à ïî ýòèì êàäðàì öâåò ïîëó÷àåòñÿ áëèæå ê èçóìðóäíîìó êàêîìóòî.........
(èñòî÷íèê âèäåî îò òàìèè ïî ñáîðêå 1/32 à6ì2 çåðî.)
Amadis ïèñàë(à):
Åñëè ñèñòåìà óáîðêè-âûïóñêà øàññè èìåëà ãèäðàâëè÷åñêèé ïðèâîä,òî îêðàñêà íèø øàññè äîëæíà áûòü îáÿçàòåëüíî ñâåòëîé,÷òîáû îáîçíà÷èòü ïîäòåêàíèÿ ãèäðîñìåñè â ïðîöåññå ýêñïëóàòàöèè.
Óâàæàåìûå ãîñïîäà! Âàäèì, êàê ÿ ïîíÿë, ñêëîíÿåòñÿ ê ìûñëè, ÷òî îêðàñêà íèø øàññè èìåëà ýêñòåðüåðíûé öâåò, èáî áîëåå ñâåòëûé, íåæåëè áàçîâûé öâåò Ï-Õ Çåðî, êîòîðûé íà ÷åðíî-áåëûõ ôîòîãðàôèÿõ êàæåòñÿ ïðîñòî áåëûì (èçâèíèòå, ïóðèñòû!), òðóäíî ñåáå ïðåäñòàâèòü. Èç òîãî æå, ÷òî ìíå ñîîáùèë êîëåãà Äèììè, è èç ïðîñìîòðåííûõ ìíîþ îáðàçöîâ "êîëåðîâ" ÿ, äà ïðîñòÿò ìåíÿ çíàòîêè ÿïîíñêîé òåõíèêè, äåëàþ âûâîä, ÷òî îçíà÷åííûé öâåò ïðè óñëîâèè ìàñøòàáíîãî âûñâåòëåíèÿ ìîæíî îõàðàêòåðèçîâàòü îïðåäåëåíèåì "ñâåòëî-ñâåòëî-îëèâêîâûé", êàêîâîé íàèëó÷øèì îáðàçîì, ÈÌÕÎ, ïðåäñòàâëåí êðàñêîé Ðåâåë "Light Olive" íîìåð 45. Ýòî î÷åíü óñëîâíî, ãîñïîäà, ïðîøó ìåíÿ ïðàâèëüíî ïîíÿòü, ïðîñòî â äàííîì ñëó÷àå ìîå âèäåíèå öâåòà ïî÷òè ñîâïàëî ñ íàçâàíèåì êðàñêè Ðåâåë, ÷òî ó ìåíÿ êàê ó õóäîæíèêà áûâàåò äàëåêî íå âñåãäà. Ìîëþ ïîïðàâèòü, åñëè îøèáñÿ, èáî ìíå æóòêî õî÷åòñÿ ðàçãàäàòü ñåêðåò ýòîé ìàãè÷åñêîé, ÷åðò âîçüìè, êðàñêè.  îòëè÷èå îò óïîìÿíóòûõ êîëëåãîé Äèììè ó÷åíûõ èíîñòðàííûõ ãîñïîä, ÿ â ýòîì ñìûñëå íè ê êàêîé øêîëå íå îòíîøóñü è âçãëÿä èìåþ, òàê ñêàçàòü, íåçàìóòíåííûé. Íî ïîëîæà ðóêó íà ñåðäöå, ñêàæó, ÷òî ìíå áîëüøå íðàâèëñÿ ïðåæíèé æåì÷óæíî-ñåðûé âàðèàíò, ñîîáùàâøèé ýòîé èçÿùíîé ìàøèíå äîïîëíèòåëüíóþ ýëåãàíòíîñòü.
Àëåêñàíäð,
ïîïðîáóéòå ñäåëàòü ìàøèíó ïîçäíèõ âûïóñêîâ ïð-âà Íàêàäçèìû - îíà êðàñèëèñü â áîëåå ñâåòëûå îòòåíêè.
Âîò ïðèìåð:
Ñëåâà, íà ìîé âçãëÿä, áîëåå-ìåíåå ïðàâèëüíàÿ îêðàñêà ìàøèí èç íàëåòà íà Ï-Õ, à ñïðàâà - îêðàñêà ìàøèí ïðîèçâîäñòâà Íàêàäçèìû.
Âïîëíå ñåáå Âàø æåì÷óæíûé âàðèàíò Smile
Äîáàâëåíî ñïóñòÿ 24 ìèíóòû 15 ñåêóíä:
Õàðóíû÷ ïèñàë(à):
Âàøà êðàñêà - âòîðàÿ ñëåâà:
Îòëè÷íûé íàãëÿäíûé ïðèìåð, êîëëåãà Äèììè. Òî, ÷òî ñëåâà, êàê ÿ ïîíèìàþ, áëèæå Âàøåìó ñåðäöó, è ñîäåðæèò êîðè÷íåâàòûé îòòåíîê, à ñïðàâà ñëîâíî áû ïðèãëóøåííûé áðèòàíñêèé çåëåíîâàòûé ÷óòü æåëòîâàòûé "ñêàé", êîòîðûé, åñëè ìíå íå èçìåíÿåò ïàìÿòü, òîæå îñíîâàòåëüíî âàðüèðîâàëñÿ. Íî ÿ, êîëëåãà Äèììè, âîò ÷òî íå ïîéìó: êàê ïðè òàêîì âåñüìà íàñûùåííîì "êîëåðå", ÷òî íà âàøåé ñõåìå ñëåâà, íà ÷åðíî-áåëûõ ôîòî ïîëó÷àëñÿ ÷óòü ëè íå áåëûé? È åùå. Ñîîáùèòå ïîæàëóéñòà ñâîå àâòîðèòåòíîå ìíåíèå îòíîñèòåëüíî íèø - íàñêîëüêî ÿ ïîíÿë, Âû òîæå ñêëîíÿåòåñü ê òîìó, ÷òîáû êðàñèòü èõ ýêñòåðüåðíûì öâåòîì? Ìíå-òî ÷òî, òàê äàæå ïðîùå, íî ñîãëàñèòåñü, ÷òî ñèíå-çåëåíûé ëàê ñ ìåòàëëèöåñêîé ïîäëîæêîé âûãëÿäåë êóäà "íàðÿäíåå", êîëè òàêîå îïðåäåëåíèå ïðèëîæèìî ê âîåííîé àâèàöèè (ìíå-òî ïðîñòèòåëüíî). È ÷òî òàêîå Sweet ¹1 - ýòî àâòîðñêàÿ èðîíèÿ (òèïà: ïîëó÷èòå, ëþáèòåëè êðàñèâåíüêîãî!) èëè èìååò êàêîå-òî îòíîøåíèå ê íàçâàíèþ öâåòà èëè ôèðìå, èçãîòàâëèâàþùåé êðàñêè?
Àëåêñàíäð,
1) Sweet - ýòî íå èðîíèÿ, à íàçâàíèå ÿïîíñêîé ôèðìû, ïðîèçâîäÿùåé ìîäåëè ñàìîëåòîâ â 144-ì ìàñøòàáå, â òîì ÷èñëå è À6Ì2:
http://www.hlj.com/product/SWT14110
Êðîìå ìîäåëåé, Sweet âûïóñêàåò êðàñêó äëÿ ñâîèõ ìîäåëåé, îñâåòëåííóþ äëÿ 144-ãî ìàñøòàáà:
http://www.hlj.com/product/SWT00025
2) Ïî ïîâîäó íèø ÿ óæå âûøå Âàì íàïèñàë Smile
Öèòàòà:
...ïðèçíàþñü ÷åñòíî, ÷òî íèøè â Àîòàêå ñìîòðÿòñÿ ãîðàçäî âûèãðûøíåå íèø â Àìå-èðî, è ÿ áû ñàì èìåííî òàê è êðàñèë, åñëè áû íå "íîâûå âåÿíèÿ"
Êñòàòè, åñòü îäèí ìîìåíò, êîòîðûé â ïîëüçó òî÷êè çðåíèÿ Èãîðÿ ãîâîðèò - â æóðíàëå ÌîäåëÃðàôèêñ (èç íàáîðà ñ À6Ì2 â 72-ì îò ÔàéíÌîëäç) ñîáèðàþò Çóéêàêîâñêèé À6Ì2 è íèøè êðàñÿò èìåííî â Àîòàêå, õîòÿ ýòî íåñîìíåííî ìàøèíà ïð-âà Ìèòñóáèñè.
3) Ïî ïîâîäó íàñûùåííîñòè êîëåðà - ýòà íîâàÿ êðàñêà XF-76 áûëà âûïóùåíà Òàìèåé îäíîâðåìåííî ñ èõ æå íîâûì À6Ì2 â 32-ì ìàñøòàáå (âîò îí: http://www.hlj.com/product/TAM60317), ïîýòîìó ìíîãèå ñ÷èòàþò, ÷òî ýòó êðàñêó íóæíî îñâåòëÿòü äëÿ ìåíüøèõ ìàñøòàáîâ. Ïðîáëåìà â òîì, ÷òî XF-76 íå ïîäõîäèò äëÿ ìàøèí ðåéäà íà Ï-Õ - îíè áûëè áîëåå êîðè÷íåâàòûå.
È åùå - âîò ôîòîãðàôèÿ EII-111 ñ Çóéêàêó:
Îáðàòèòå âíèìàíèå íà êîíòðàñò ìåæäó çàâåäîìî áåëûìè ïîëîñàìè èäåíòèôèöèðîâàíèÿ è îñíîâíûì öâåòîì ìàøèíû.
Èëè âîò åùå îäíà ôîòîãðàôèÿ:
Íà ìîÿ âçëÿä - î÷åíü ïîõîæå íà òî, ÷òî ó ìåíÿ ïîëó÷èëîñü:
Ñðàçó õî÷ó ñêàçàòü, ÷òî ñâîþ òî÷êó çðåíèÿ ÿ íèêîìó íå íàâÿçûâàþ Smile
Êîëëåãà Äèììè! Áîëüøîå ñïàñèáî çà îáÿúñíåíèÿ. Îíè äîñòàòî÷íî èñ÷åðïûâàþùèå. ß ïîíèìàþ, ÷òî ñâîþ òî÷êó çðåíèÿ Âû íèêîìó íå íàâÿçûâàåòå, ïðîñòî îíà ó Âàñ åñòü. À ýòî äîðîãîãî ñòîèò.
êóïèë ñåãîäíÿ ãðóíò, è íåîáõîäèìûå öâåòà.
çàêîí÷ó òðåíèðîâàòüñÿ íà òåêóùåé ìîäåëè, è íà÷íó ïîòèõîíüêó ñáîðêó.
À ÷òî äóìàþò, óâàæàåìûå çíàòîêè ïî ïîâîäó êðàñêè Tamiya XF-71 Cockpit Green (IJN) äëÿ íèø øàññè è èíòåðüåðà À6Ì5 ïð-âà Ìèòñóáèñè? È âîîáùå ïî-ïîâîäó àäåêâàòíîñòè ýòîé êðàñêè?
Ñòðàíèöà 2 èç 2 Íà ñòðàíèöó Ïðåä.  12
Ïåðåéòè:
Âû íå ìîæåòå íà÷èíàòü òåìû
Âû íå ìîæåòå îòâå÷àòü íà ñîîáùåíèÿ
Âû íå ìîæåòå ðåäàêòèðîâàòü ñâîè ñîîáùåíèÿ
Âû íå ìîæåòå óäàëÿòü ñâîè ñîîáùåíèÿ
Âû íå ìîæåòå ãîëîñîâàòü â îïðîñàõ
Âû íå ìîæåòå âêëàäûâàòü ôàéëû
Âû íå ìîæåòå ñêà÷èâàòü ôàéëû
Image Map Êàíàë íà Äçåíå Òåëåãðàì ScaleModels.ru Âêîíòàêòå Ïîäïèñàòüñÿ íà RSS
Àâòîðàì - ïëþøêè! Ïîääåðæè ñàéò ScaleModels.ru! Çàãðóçè ñâîþ ìîäåëü!
ScaleModels.ru - ñáîðíûå ìàñøòàáíûå ìîäåëè. © 2005-2025
