B-29-1-BW 42-6223 Lady BOOMERANG of the 770th BS/462nd BG, Pairdoba, India, July 1944
Lady BOOMERANG was constructed as part of the first B-29 production block of 50 aircraft built by Boeing following completion of the 14 pre-production YB-29s. One of the original Superfortresses assigned to the 462nd BG, on 16 December 1943, its first aircraft commander was Capt Smith, who was later replaced by Capt J M Miller. The aircraft was lost whilst being flown by the latter crew when it ran out of fuel following a mission to Singapore on 23 August 1944. Two crewmen were killed in the crash-landing and Lady BOOMERANG was salvaged three days later. It was one of the few B-29s finished in the AAF's early war olive drab scheme - note that its wings have bare metal leading edges following the removal of their rubber de-icing boots. The bomber also has the early two gun upper forward turret and mixed 0.50-cal machine guns/20 mm cannon tail armament. Crews had been instructed to remove the cannon in September 1944, but some chose to retain them after that date. Lady BOOMERANG appears in the group's early CBI markings, its B-29s being adorned with 63-in aeroplane-in-squadron identifying letter codes located above the radio call number on the fin, whilst the rudders were painted with the squadron colour. When the units were reorganised in October 1944, all group aircraft had their rudders painted red, the squadrons then being indicated by a 4-ft number applied below the radio code - the 771st was disbanded at this time. Lady BOOMERANG, like other early 462nd BG B-29s, has its nose art applied on the starboard side.
Вот тут (смотрим внимательно фото по ссылке приведенной выше http://www.pacificstorm.net/Articles/A-bomb/a-bomb.htm ) бомбу подвешивают под борт с буквой (R) на хвосте, а выруливает типа "для вклада в историю" борт со стрелой на хвосте!
Всегда возникает сомнение в достоверности материала, опубликованного в таких вот (не щепетильных к исходникам) источниках.
Хломос
Жаль, что не строите Энолу, лично мне наиболее интересен этот борт. Я смотрю, что у Вас просто ранняя модель Академа. В моем наборе есть и винты и бомба для Энолы...
Тем не менее, с интересом понаблюдаю за сборкой.
Добавлено: Пт Дек 16, 2011 12:28 am
Коллеги, спасибо! Тема затихла из за некоторых проблем возникших с приобретением нужных декалей, а до этого я не смогу определиться с конкретным бортом.
